CWP Grounding Clamps
By POWER
ERICO has developed a range of CWP grounding clamps that are ideal for use in applications including lightning protection, fault current ground, signal reference grid, and static ground. The clamps help minimize the possibility of damage from a lightening strike or other transient voltage by reducing the electrical potential between metallic objects and building systems. Part of the ERITECH line of "Facility Electrical Protection" products, the clamps conform to new requirements from the National Fuel Gas Code and National Electric Code for bonding corrugated stainless steel tubing (CSST) gas piping systems to the grounding conductor of the building’s electrical system.
CWP Grounding Clamps are ideal for connecting brass hex fittings on flexible gas piping, copper grounding conductors, galvanized water pipes, copper water tubing, or ground rods ranging from ½ inch to 4 inch to a ground conductor to bond all ground points together. This helps eliminate ground loops and creates an equipotential plane. The clamps are made of high-strength silicone bronze. (www.erico.com)
