Don’t miss out on some of POWER’s most-read, recent stories
The Natural Gas Flame Continues to Burn Bright
The natural gas sector is well aware of the challenges facing the fossil fuel industry, but analysts say gas has attributes that will keep it a big part of the U.S. and global energy mix.
Read More
Fending Off Forced Power Plant Outages
The changing profile of the power system has added new stressors on conventional power generation and may have raised the potential for forced outages. Addressing them requires a closer look at traditional and emerging risks.
Read More
Improving Load Response and NOx Emissions with Boiler Tuning and Coal-Fired Unit Optimization
Maintaining and operating a coal-fired generating station requires the utmost attention to detail to stay competitive. Focusing on the fundamentals of combustion allows engineers to improve reliability, emissions, and efficiency.
Read More
The Allure of TRISO Nuclear Fuel Explained
Tristructural isotropic (TRISO) particle fuel has long been used in high-temperature gas-cooled nuclear reactors, but it is seeing a resurgence as a result of other applications. Modern TRISO fuel designs are under consideration for an assortment of advanced reactors, including high-temperature reactors and microreactors, and even as accident-tolerant fuel for light water reactors.
Read More
‘Best Is Yet to Come’ for Energy Storage Technology
Advancements in batteries, along with an improved regulatory environment and more investment, could make this decade the Roaring ’20s for energy storage.
Read More
First Commercial Deployment of Supercritical CO2 Power Cycle Taking Shape in Alberta
Siemens Energy and Canadian pipeline company TC Energy in February agreed to commission a novel waste-heat-to-power facility in Alberta by 2022 that captures waste heat from a gas-fired turbine operating a pipeline compression station, and then converts it into power using an innovative supercritical carbon dioxide (sCO2) power cycle.
Read More
Oil and Gas Majors Focus on Renewable Energy, Hydrogen, and Carbon Capture
Although you’d be hard-pressed to find an expert who believes oil and gas companies will abandon exploration and production operations anytime soon, several oil and gas majors are expanding their businesses into the renewable energy sector—and some in a big way. Total has laid out plans that would have it outpace clean energy leaders Iberdrola and Ørsted on renewable power capacity by 2030. Hydrogen and carbon capture technologies are also likely to be part of growth strategies for the industry going forward.
Read More
Understanding Hydro Turbine Draft Tubes and Their Importance
Significant engineering goes into every hydropower facility. Among the items that require detailed design work are draft tubes, which are basically conical diffusers installed at the outlet of turbine runners. This seldom-mentioned feature is highly important to turbine efficiency.
Read More
