Custom catalyst commercialization II: Adding Value through Research & Development
Thursday, May 9,11:00 AM CT
REGISTER NOW
Register to attend this complimentary online webinar.
All registered attendees will receive a certificate of completion for one professional development hour
Sponsored By:
Hosted By:
| • Webinar Summary |
| • Hear from the Experts |
| • Support & Troubleshooting |
| • Questions? |
Webinar Summary: |
In this second webinar in the series “Custom Catalyst Commercialization” we will show how the involvement of BASF R&D can enhance either the current custom catalyst or lead to greatly improved second generation products, while maintaining the Intellectual Property (IP) protection that is critical to the custom catalyst relationship.
This webinar builds on information presented previously on development scenarios, scale-up and manufacturing processes, catalyst and process knowledge and expertise, as well as confidentiality and Intellectual Property (IP) protection.
The webinar will conclude with a live question and answer session with BASF scientists and experts
Viewers Will Learn: |
- What the value of heat rate is to your business, and how heat rate correlates to return on investment.
- The key causes of feedwater heater inefficiency and subsequent effects on overall plant performance.
- How effective feedwater heater level control can maximize energy transfer and manage controllable losses and fuel cost acceleration.
Webinar Topics Overview: |
- Understanding Heat Rate
- The Cost of Heat Rate Deviation
- Feedwater Heaters’ Role in the Basic Power Cycle
- Monitoring Performance of Feedwater Heaters
- Feedwater Heater Level Control and the Impact of Instrument-Induced Errors
- Controlling Energy Loss Through Level Optimization
Who Should Attend: |
- Engineering Managers
- Efficiency Managers
- Operations Managers
- Maintenance Managers
- I&C/E&I Supervisors
Hear from these experts: |
Donald Hite Donald Hite has conducted seminars and trained power plant operators worldwide on best practices for optimizing critical power generation applications using advanced radar level technology. He has 30 years of instrumentation expertise, acquired through his current position at Magnetrol, and prior positions at the U.S. Air Force, Honeywell and Thermo Scientific. Coupled with his studies in Computer Science at the University of Southern Mississippi, Donald is also a certified Master Instructor and has designed and conducted technical training courses on Inertial and Radar Navigation Systems, Level Measurement and Control Technologies, Data Acquisition and Management Processes, and Heat Rate and Feedwater Heater Level Control. |
Moderator: |
David Wagman Executive Editor POWER magazine David Wagman is Executive Editor of POWER magazine and Content Director for the ELECTRIC POWER conference. David has more than 20 years of experience writing about and developing content related to the energy industry, including electric power generation and regulation. He holds an MS in City and Regional Planning from Ohio State University and is based in Denver, Colorado. |
What do I need to view this Webcast? |
Minimum Requirements:
| Operating System | Processor | RAM | Internet Browser | Hardware | Media Players | Internet Connection |
Windows 7 1 Windows Vista Windows XP SP3 Note: Mac OS X and Linux users please click here. |
Pentium III 733mhz+ or equivalent | 512MB |
Internet Explorer 6.0+ 2 Firefox 3.0+ Pop-up Blocking Software Disabled 3 |
AUDIO: Sound Card with speakers VIDEO: Monitor with 1024×768+ resolution support |
Windows Media Player 9+ Adobe Flash Player 9.1+ 4 |
High speed Cable / Fiber / DSL 5 Corporate LAN 6 |
1 Older Windows operating systems, including Windows 2000, will most likely work but are not officially supported. Please consulthttp://support.microsoft.com/default.aspx?pr=lifesupsps to determine if your operating system is still supported by Microsoft.
2 For security and performance reasons it is strongly advised to upgrade to the latest version of Internet Explorer.
3 The presentation is built on pop-upless technology; however, the presenter may choose to use pop-up windows. In these cases, pop-up blocking software must be disabled for the presentation to work correctly. In many cases, holding down the "CTRL" key while opening the Webcast URL will temporarily disable your pop-up blocking software. Please consult the documentation for your pop-up blocking software to determine the correct way to temporarily disable it.
4 In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings.
5 High speed Cable / Fiber / DSL. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
6 Corporate LAN. Bandwith on corporate LANs can vary based on network traffic. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
What support is available for users on Macintosh and Unix/Linux-Based operating systems?
This presentation incorporates advanced multimedia features that allow elements such as slides, polling questions, surveys, and application demonstrations to be dynamically sent to the audience synchronized with the presentation. Mac and Linux audiences may view the presentation using a supported Firefox Web browser and Adobe Flash player. Please note that some presentations may not feature a Flash option.
Why can’t I hear audio?
- If you have internal speakers, make sure they aren’t muted.
- If you have external speakers, make sure they are powered on and aren’t muted.
- Make sure you did not lose Internet connectivity.
- Make sure you have the media player installed that you are attempting to use and the plugin is correctly installed within the browser.
- If you are using Windows Media Player and the player simply stops and/or gives you a generic "error" message, you may be missing an audio codec required to decode the presentation audio. Click here for the Microsoft Codec Installation Package.
Alternatively, you can download the latest player here: http://www.microsoft.com/windows/windowsmedia/download/ - If you are using Adobe Flash Player and are having connection issues please refer to the section labeled "Why do I get a "connection failed" or "connection blocked" message when I try to view Adobe Flash streams?"
What is a pop-up blocker and how do I disable it?
Pop-up blockers are software programs that stop unsolicited "pop-up" browser windows from launching automatically. These windows often feature advertisements that can be an annoyance to users trying to browse the Internet, however some features of the Webcast may make use of pop-up windows to deliver key functionality. Depending on the software progam you have installed you may be able to add the Web site URL to a list of permissible Web sites where pop-up windows are allowed.
It is common to have one or more pop-up blockers that you may be unaware of. Most pop-up blockers reside either in the system tray (lower right hand corner of your screen by the clock) or as a toolbar in Internet Explorer (at the top of your browser, go to "View" and then "Toolbars"). These can be disabled in their options or preferences menus. (Common toolbars such as Google and Yahoo Companion have built in pop up blockers).
Also, if you are unaware of any other pop-up blockers that are running on your computer, you may want to see if you have personal firewall software running, such as Norton’s Internet Security or ZoneAlarm. If you have either of these, they will also block pop-up windows.
Where can I download the latest streaming media players?
– Windows Media Player – http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx
– Adobe Flash (for viewing Application Demonstrations and Video Roll-ins) – http://get.adobe.com/flashplayer/
Where can I download the latest Internet browsers?
– Microsoft Internet Explorer 8 – http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
– Previous versions of IE – http://www.microsoft.com/windows/ie/ie6/downloads/default.mspx
– Firefox – http://www.mozilla.com/firefox/
I occasionally hear a clicking noise during the presentation. How do I turn it off?
- Windows 7 – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows Vista – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows XP – You can disable this noise by going to the Start menu, then "Control Panel". Open "Sounds and Audio Devices," and click the "Sounds" tab. Scroll down the "Program Events" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings. IT Admins can click here to review additional information on configuring proxy servers to permit live Flash streaming.
Questions? |
Please contact Jennifer Brady, POWER Marketing Coordinator at 713-343-1906 or jenniferb@tradefairgroup.com
.jpg)
