Whitepaper: Enhancing Grid Resilience and Wildfire Mitigation with TESCO’s Backup Power Transfer Meter (BPTM)
Published: June 9, 2025
Fill out the form to access the full whitepaper
As climate-driven outages grow more frequent, utility leaders face mounting pressure to deliver safe, reliable backup power—especially in wildfire-prone regions. TESCO’s Backup Power Transfer Meter (BPTM), developed in collaboration with PG&E, is redefining how utilities approach temporary power deployments with safety, compliance, and operational efficiency at the core.
Why PSPS and wildfire events demand smarter backup power metering
The dangers and liabilities of improvised generator setups—and how to eliminate them
How the BPTM delivers automatic transfer switching, surge protection, and utility-grade metering in under 45 minutes
Case study: PG&E’s real-world success with BPTM deployments in fire-prone regions
How the BPTM helps utilities meet CPUC, FERC/NERC, and grant reporting requirements with auditable data
Whether you’re in procurement, field operations, or resilience planning, the BPTM gives you:
Fast, repeatable field deployment with no rewiring or panels
Enhanced technician safety and customer protection
Accurate usage data for post-event reporting and compliance
A scalable, cost-effective solution for PSPS, storms, and critical care support
With proven field success, U.S.-based manufacturing, and full support for regulatory documentation, the BPTM is setting a new standard in emergency power metering.
Fill out the form to receive your copy of the whitepaper and learn how TESCO’s BPTM can support your utility’s wildfire mitigation and resilience goals.
You’ll also receive access to deployment specs, case studies, and an option to request a demo.
