Maximum Value with Minimum Risk from Siemens COMOS FEED Solutions
Thursday, July 28, 11:00am Central Time
Schedule this FREE webinar with your team – no travel required. All registered attendees will receive a certificate of completion for one professional development hour!
Spronsored By:
| • Webinar Summary |
| • Hear from the Experts |
| • Support & Troubleshooting |
| • Questions? |
Webinar Summary: |
Are you looking at ways to automate and manage your I&C design documentation?
Most instrumentation projects require the same type of documentation – loops, lists, schedules etc. – but rarely in exactly the same format. Typically, those involved in a project’s design will work independently on constantly evolving P&IDs or Excel files for instrument lists, cable schedules, termination details, and I/O lists. The CAD drafter will then attempt to consolidate this information in drawing format. It can be quite a process for all involved to be working from the same page and to provide accurate and up to date data.
SCADA Systems, an Autodesk development partner for close to 20 years, provides an instrument design and management solution that shares data from AutoCAD’s intelligent P&ID software, AutoCAD P&ID, on an SQL platform to create drawings, datasheets, and reports.
What Viewers Will Learn: |
Viewers will learn that using AutoCAD P&ID and Instrument Manager will allow users to:
• Create a Centralized project management / reference system
• See how a smart AutoCAD / database solution provides data consistency and accuracy
• Generate major productivity gains using automated design documentation
• Quickly generate output deliverables such as loop, hookups, wiring diagrams, datasheets
• Easily Customize all output documents to end-client standards including instrument index, I/O lists, cable schedules
• Design projects quickly and intuitively
• Work with system and output files based on familiar and future-proof file formats ie AutoCAD, Excel, SQL Server
Hear from the experts: |
Andy Bonfield Andy Bonfield has been with SCADA Systems for 7 years and is responsible for sales and marketing of electrical and instrumentation software particularly in the plant and process markets. He has been involved in the product development of SCADA’s database driven I&C design software, Instrument Manager, as well as creating product demonstrations and marketing initiatives. |
Harold G. Monk Harold Monk has extensive knowledge and experience in piping design and a wide variety of design software programs. He has more than 14 years of collective experience in the engineering space. His experience includes piping design, estimating, training, software customization and software administration. Harold holds an Associate’s Degree from Delta Junior College in Baton Rouge, Louisiana. |
Moderator: |
Julien DuPont Julien DuPont has approximately 20 years of collective experience in the conference, exhibition, offshore and construction industries. He is currently a Sales Director for DIGITAL PLANT and ChemInnovations which serve the process, power and offshore industries. With more and more educational content being disseminated via webinars, Julien is actively utilizing this e-media format to serve the industry. Julien holds a BBA from Stephen F. Austin State University. |
What do I need to view this Webcast? |
Minimum Requirements:
| Operating System | Processor | RAM | Internet Browser | Hardware | Media Players | Internet Connection |
Windows 7 1 Windows Vista Windows XP SP3 Note: Mac OS X and Linux users please click here. |
Pentium III 733mhz+ or equivalent | 512MB |
Internet Explorer 6.0+ 2 Firefox 3.0+ Pop-up Blocking Software Disabled 3 |
AUDIO: Sound Card with speakers VIDEO: Monitor with 1024×768+ resolution support |
Windows Media Player 9+ Adobe Flash Player 9.1+ 4 |
High speed Cable / Fiber / DSL 5 Corporate LAN 6 |
1 Older Windows operating systems, including Windows 2000, will most likely work but are not officially supported. Please consult http://support.microsoft.com/default.aspx?pr=lifesupsps to determine if your operating system is still supported by Microsoft.
2 For security and performance reasons it is strongly advised to upgrade to the latest version of Internet Explorer.
3 The presentation is built on pop-upless technology; however, the presenter may choose to use pop-up windows. In these cases, pop-up blocking software must be disabled for the presentation to work correctly. In many cases, holding down the "CTRL" key while opening the Webcast URL will temporarily disable your pop-up blocking software. Please consult the documentation for your pop-up blocking software to determine the correct way to temporarily disable it.
4 In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings.
5 High speed Cable / Fiber / DSL. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
6 Corporate LAN. Bandwith on corporate LANs can vary based on network traffic. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
What support is available for users on Macintosh and Unix/Linux-Based operating systems?
This presentation incorporates advanced multimedia features that allow elements such as slides, polling questions, surveys, and application demonstrations to be dynamically sent to the audience synchronized with the presentation. Mac and Linux audiences may view the presentation using a supported Firefox Web browser and Adobe Flash player. Please note that some presentations may not feature a Flash option.
Why can’t I hear audio?
- If you have internal speakers, make sure they aren’t muted.
- If you have external speakers, make sure they are powered on and aren’t muted.
- Make sure you did not lose Internet connectivity.
- Make sure you have the media player installed that you are attempting to use and the plugin is correctly installed within the browser.
- If you are using Windows Media Player and the player simply stops and/or gives you a generic "error" message, you may be missing an audio codec required to decode the presentation audio. Click here for the Microsoft Codec Installation Package.
Alternatively, you can download the latest player here: http://www.microsoft.com/windows/windowsmedia/download/ - If you are using Adobe Flash Player and are having connection issues please refer to the section labeled "Why do I get a "connection failed" or "connection blocked" message when I try to view Adobe Flash streams?"
What is a pop-up blocker and how do I disable it?
Pop-up blockers are software programs that stop unsolicited "pop-up" browser windows from launching automatically. These windows often feature advertisements that can be an annoyance to users trying to browse the Internet, however some features of the Webcast may make use of pop-up windows to deliver key functionality. Depending on the software progam you have installed you may be able to add the Web site URL to a list of permissible Web sites where pop-up windows are allowed.
It is common to have one or more pop-up blockers that you may be unaware of. Most pop-up blockers reside either in the system tray (lower right hand corner of your screen by the clock) or as a toolbar in Internet Explorer (at the top of your browser, go to "View" and then "Toolbars"). These can be disabled in their options or preferences menus. (Common toolbars such as Google and Yahoo Companion have built in pop up blockers).
Also, if you are unaware of any other pop-up blockers that are running on your computer, you may want to see if you have personal firewall software running, such as Norton’s Internet Security or ZoneAlarm. If you have either of these, they will also block pop-up windows.
Where can I download the latest streaming media players?
– Windows Media Player – http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx
– Adobe Flash (for viewing Application Demonstrations and Video Roll-ins) – http://get.adobe.com/flashplayer/
Where can I download the latest Internet browsers?
– Microsoft Internet Explorer 8 – http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
– Previous versions of IE – http://www.microsoft.com/windows/ie/ie6/downloads/default.mspx
– Firefox – http://www.mozilla.com/firefox/
I occasionally hear a clicking noise during the presentation. How do I turn it off?
- Windows 7 – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows Vista – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows XP – You can disable this noise by going to the Start menu, then "Control Panel". Open "Sounds and Audio Devices," and click the "Sounds" tab. Scroll down the "Program Events" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings. IT Admins can click here to review additional information on configuring proxy servers to permit live Flash streaming.
Questions? |
Please contact DIGITAL PLANT Marketing Manager, Gabe Geller at (713) 343-1893 or email: ggeller@tradefairgroup.com.
