The BelGAS division of Marsh Bellofram Corp. introduced Type P627, a high-performance, spring-loaded, direct-operating high-flow gas regulator that is designed to control both low- and high-output pressure in oil and gas applications. Designed for maximum durability, Marsh Bellofram BelGAS Type P627 regulators are compact and offered in multi-position body and spring case configurations. Units offer installation versatility, ease of operation, and set pressures, as well as a wide range of available flow capacities and spring ranges. Regulators are also available in an external pressure registration model (P627M) and with optional National Standard of Corrosion Engineers–compliant construction. (http://www.marshbellofram.com)
