HARRINGTON HOISTS, INC. INTRODUCES HARRINGTON HSC GRADE 100 SLING CHAIN
Manheim, PA – Harrington Hoists, Inc., recently released super strong, Grade 100 Sling Chain which is used to make chain slings when appropriate sling fittings are attached. Typical applications requiring sling chain are those involving the lifting of heavy loads or repetitive lifting situations in construction, foundries, steel mills, and heavy machining processes.
Harrington Grade 100 Sling Chain is durable, flexible and will tolerate a wide range of temperatures. It is exceptionally economical due to its long wear life and is easy to inspect, handle and store.  This product is currently offered in three chain diameters of 9/32” (7mm), 3/8” (10mm), and 1/2” (13mm).
Harrington Hoists, Inc., a KITO Group Company, is a leading supplier and manufacturer of electric chain and wire rope hoists, air powered hoists, lever hoists, manual hand chain hoists, trolleys, cranes, crane components and a full line of replacement parts.
