Low-Noise Remote Charge Converter
Endevco Corp. launched Model 2771C-XX, an ultra-low-noise remote charge converter (RCC) designed for use with charge output piezoelectric sensors within applications such as nuclear power plant/regenerative energy and environmental testing. The model offers a rugged two-wire (IEPE), single-ended design that operates from constant current power (4-20 mA). Both RCC signal output and current to the RCC are carried along the same wire. Housed in a small package, the charge converter offers broadband noise range down to 5µ V rms, with a frequency response of 0.4 to 50 kHz. Units are designed to withstand shock loads of up to 100-g peak and are radiation tested to 1.0 Mrads. The model is available with three different fixed gains: 0.1 mV/pC, 1.0 mV/pC, and 10 mV/pC. It can also support TEDS (per IEEE P1451.4) for smart sensor and larger channel count applications and includes an available M1 Version with male BNC, to facilitate easy panel mounting. (www.endevco.com)
Inclusion in New Products does not imply endorsement by POWER magazine.
