Learn How To Improve Electrical Safety in Coal Handling Areas
Nuclear Webinar: Case Study of Implementation of Guidelines
Wednesday, September 11
11:00 A.m. (C.S.T.)
Register Now!
And, bring your entire team!
| • Webinar Summary |
| • Meet the Speakers |
| • Support & Troubleshooting |
| • Questions? |
Webinar Summary: |
The purpose of this presentation is to discuss what a nuclear utility should establish and consider when implementing digital technologies in their plant(s).
Digital technologies have been employed in many safety critical industries such as aerospace, pharmaceutical, and chemical. However, nuclear industry implementation of digital technologies has been slow and tenuous. Numerous operating experience events are documented in which plant trips/SCRAMs occurred as a result of defective or deficient digital system implementation. This presentation aims to prevent those issues.
What Viewers Will Learn: |
The attendee will be able to describe recommended practices related to implementing electrical best practices. The attendee will learn:
• How to Identify Hazards
• Review Hazardous Area Location definitions (NEC , NFPA)
• Find Hazardous Location at Site
• What Upgrade Equipment will meet (NEC, NFPA)
• How to Mitigate the Hazards
• How to Maintain and Install Other Equipment in an Approved Manner
Who Should Attend: |
The intended audience for this presentation is:
• nuclear utility executives
• Plant Management
• directors
• managers
• engineers
Hear from the experts: |
Chris Wiegand Christopher Wiegand retired from Exelon Nuclear after 22 years with the company in which he held positions at nuclear sites and corporate in Engineering, Operations, and Maintenance. He received an SRO license at Braidwood station and holds a professional engineer license in Illinois. He was EPRI’s I&C Steering Committee Chairman from 2004 to 2010. He was on the American Nuclear Society’s Operations & Power Division Executive Committee from 2007 to 2010 and is currently on the Human Factors and I&C Executive Committee. He currently is a nuclear executive with Invensys Operations Management, a global technology company specializing in digital solutions for the nuclear industry. |
Mike Phillips BS Environmental Engineering from Cal Poly San Luis Obispo. Over 30 years of Controls Experience with Texas Instruments, GE, Triconex and Invensys. For the last 11 years instrumental in driving the Triconex 1E qualification efforts and shaping the Invensys Nuclear Strategy. Presently reporting to the VP Invensys Nuclear and responsible for setting the Global Nuclear Strategy for the Invensys portfolio of products and services supplied to the nuclear industry |
Moderator: |
What do I need to view this Webcast? |
Minimum Requirements:
| Operating System | Processor | RAM | Internet Browser | Hardware | Media Players | Internet Connection |
Windows 7 1 Windows Vista Windows XP SP3 Note: Mac OS X and Linux users please click here. |
Pentium III 733mhz+ or equivalent | 512MB |
Internet Explorer 6.0+ 2 Firefox 3.0+ Pop-up Blocking Software Disabled 3 |
AUDIO: Sound Card with speakers VIDEO: Monitor with 1024×768+ resolution support |
Windows Media Player 9+ Adobe Flash Player 9.1+ 4 |
High speed Cable / Fiber / DSL 5 Corporate LAN 6 |
1 Older Windows operating systems, including Windows 2000, will most likely work but are not officially supported. Please consult http://support.microsoft.com/default.aspx?pr=lifesupsps to determine if your operating system is still supported by Microsoft.
2 For security and performance reasons it is strongly advised to upgrade to the latest version of Internet Explorer.
3 The presentation is built on pop-upless technology; however, the presenter may choose to use pop-up windows. In these cases, pop-up blocking software must be disabled for the presentation to work correctly. In many cases, holding down the "CTRL" key while opening the Webcast URL will temporarily disable your pop-up blocking software. Please consult the documentation for your pop-up blocking software to determine the correct way to temporarily disable it.
4 In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings.
5 High speed Cable / Fiber / DSL. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
6 Corporate LAN. Bandwith on corporate LANs can vary based on network traffic. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
What support is available for users on Macintosh and Unix/Linux-Based operating systems?
This presentation incorporates advanced multimedia features that allow elements such as slides, polling questions, surveys, and application demonstrations to be dynamically sent to the audience synchronized with the presentation. Mac and Linux audiences may view the presentation using a supported Firefox Web browser and Adobe Flash player. Please note that some presentations may not feature a Flash option.
Why can’t I hear audio?
- If you have internal speakers, make sure they aren’t muted.
- If you have external speakers, make sure they are powered on and aren’t muted.
- Make sure you did not lose Internet connectivity.
- Make sure you have the media player installed that you are attempting to use and the plugin is correctly installed within the browser.
- If you are using Windows Media Player and the player simply stops and/or gives you a generic "error" message, you may be missing an audio codec required to decode the presentation audio. Click here for the Microsoft Codec Installation Package.
Alternatively, you can download the latest player here: http://www.microsoft.com/windows/windowsmedia/download/ - If you are using Adobe Flash Player and are having connection issues please refer to the section labeled "Why do I get a "connection failed" or "connection blocked" message when I try to view Adobe Flash streams?"
What is a pop-up blocker and how do I disable it?
Pop-up blockers are software programs that stop unsolicited "pop-up" browser windows from launching automatically. These windows often feature advertisements that can be an annoyance to users trying to browse the Internet, however some features of the Webcast may make use of pop-up windows to deliver key functionality. Depending on the software progam you have installed you may be able to add the Web site URL to a list of permissible Web sites where pop-up windows are allowed.
It is common to have one or more pop-up blockers that you may be unaware of. Most pop-up blockers reside either in the system tray (lower right hand corner of your screen by the clock) or as a toolbar in Internet Explorer (at the top of your browser, go to "View" and then "Toolbars"). These can be disabled in their options or preferences menus. (Common toolbars such as Google and Yahoo Companion have built in pop up blockers).
Also, if you are unaware of any other pop-up blockers that are running on your computer, you may want to see if you have personal firewall software running, such as Norton’s Internet Security or ZoneAlarm. If you have either of these, they will also block pop-up windows.
Where can I download the latest streaming media players?
– Windows Media Player – http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx
– Adobe Flash (for viewing Application Demonstrations and Video Roll-ins) – http://get.adobe.com/flashplayer/
Where can I download the latest Internet browsers?
– Microsoft Internet Explorer 8 – http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
– Previous versions of IE – http://www.microsoft.com/windows/ie/ie6/downloads/default.mspx
– Firefox – http://www.mozilla.com/firefox/
I occasionally hear a clicking noise during the presentation. How do I turn it off?
- Windows 7 – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows Vista – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows XP – You can disable this noise by going to the Start menu, then "Control Panel". Open "Sounds and Audio Devices," and click the "Sounds" tab. Scroll down the "Program Events" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings. IT Admins can click here to review additional information on configuring proxy servers to permit live Flash streaming.
Questions? |
Please contact Kim Arellano, Conference Director, at (713) 343-1879 or email: kima@tradefairgroup.com.
