Clean and Efficient Biomass and Waste Utilization in Utility Industry
Date: Thursday, November 10, 2011
Time: 11:00AM – 12:00 noon Eastern
VIEW ON DEMAND
Register for free and bring your entire team!
| • Webinar Summary |
| • Meet the Speakers |
| • Support & Troubleshooting |
| • Questions? |
Webinar Summary: |
Biomass (woodchips, switch grass, animal waste) and Municipal solid wastes is a renewable and sustainable energy resource. This webinar is aimed at sharing users’ experience with transportation, storing, handling, preparing, and using biomass and wastes. Cofiring and stand-alone projects as well as the basic considerations will be covered. Different means to reform biomass and wastes to clean and efficient energy will be considered.
What Viewers Will Learn: |
The attendee will learn
- The issues to consider when defining your biomass firing program
- Lean how to use negative cost low grde fuels for your plant
- Learn about efficient and economical treatment of landfill gas for gas turbine applications and the favorable plant economics
- Explore means to use low grade fuels in your boilers or furnaces and save fuel costs and enhance reliability of fuels availability at affordable costs for increased profits. The pay back for the upgrade can be achieved in a very short period of time.
- Reduce environmental compliance costs and environmental impact. Learn how to make impact on achieving cleaner environment even with the use of low grade fuels, biomass and wastes and enhance boiler/furnace life with no fouling and slagging of the furnace/boiler.
- Learn how the recent advances have helped promote rapid implementation of the new technologies successfully in many plants worldwide. Example case studies will also be presented.
- Hear from other users and members of common interest on cost effective use of wastes and biomass in their plants
Who Should Attend: |
The intended audience for this presentation is:
- Generation Business Managers
- Fuels Managers
- Project Managers
- Operations Managers
- Engineering Managers
- Fuel Handling Managers
- Engineering/Technical Services Managers
- Environmental Compliance Managers
- Plant Engineers
- Research Engineers
- Environmental Engineers
- Waste Management Engineers
- Business Development Managers
Who Else Should Attend:
- Engineering/Procurement/Construction Companies
- OEM’s
- Fuel Suppliers
- Research & Development Organizations
- Consultants
Hear from the experts: |
Marco Castaldi
Professor Castaldi has been engaged in research on thermal conversion technology of waste and biomass for the past seven years at |
Chris Blazek
Amanda Hamsley Lang Amanda Hamsley Lang leads Forisk’s bioenergy research and is the Managing Editor of Wood Bioenergy US. Amanda is also Operations Manager at Forisk and manages day-to-day operating activities associated with consulting projects, educational programming, and publications/subscriptions. Her professional experience includes internships with International Paper in |
Ashwani Gupta Ashwani Gupta is Distinguished University Professor at the University of |
What do I need to view this Webcast? |
Minimum Requirements:
| Operating System | Processor | RAM | Internet Browser | Hardware | Media Players | Internet Connection |
Windows 7 1 Windows Vista Windows XP SP3 Note: Mac OS X and Linux users please click here. |
Pentium III 733mhz+ or equivalent | 512MB |
Internet Explorer 6.0+ 2 Firefox 3.0+ Pop-up Blocking Software Disabled 3 |
AUDIO: Sound Card with speakers VIDEO: Monitor with 1024×768+ resolution support |
Windows Media Player 9+ Adobe Flash Player 9.1+ 4 |
High speed Cable / Fiber / DSL 5 Corporate LAN 6 |
1 Older Windows operating systems, including Windows 2000, will most likely work but are not officially supported. Please consult http://support.microsoft.com/default.aspx?pr=lifesupsps to determine if your operating system is still supported by Microsoft.
2 For security and performance reasons it is strongly advised to upgrade to the latest version of Internet Explorer.
3 The presentation is built on pop-upless technology; however, the presenter may choose to use pop-up windows. In these cases, pop-up blocking software must be disabled for the presentation to work correctly. In many cases, holding down the "CTRL" key while opening the Webcast URL will temporarily disable your pop-up blocking software. Please consult the documentation for your pop-up blocking software to determine the correct way to temporarily disable it.
4 In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings.
5 High speed Cable / Fiber / DSL. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
6 Corporate LAN. Bandwith on corporate LANs can vary based on network traffic. Typical connection speeds can vary from 100Kbps – 1Mbps+. Please check with your local ISP for bandwidth allotment.
What support is available for users on Macintosh and Unix/Linux-Based operating systems?
This presentation incorporates advanced multimedia features that allow elements such as slides, polling questions, surveys, and application demonstrations to be dynamically sent to the audience synchronized with the presentation. Mac and Linux audiences may view the presentation using a supported Firefox Web browser and Adobe Flash player. Please note that some presentations may not feature a Flash option.
Why can’t I hear audio?
- If you have internal speakers, make sure they aren’t muted.
- If you have external speakers, make sure they are powered on and aren’t muted.
- Make sure you did not lose Internet connectivity.
- Make sure you have the media player installed that you are attempting to use and the plugin is correctly installed within the browser.
- If you are using Windows Media Player and the player simply stops and/or gives you a generic "error" message, you may be missing an audio codec required to decode the presentation audio. Click here for the Microsoft Codec Installation Package.
Alternatively, you can download the latest player here: http://www.microsoft.com/windows/windowsmedia/download/ - If you are using Adobe Flash Player and are having connection issues please refer to the section labeled "Why do I get a "connection failed" or "connection blocked" message when I try to view Adobe Flash streams?"
What is a pop-up blocker and how do I disable it?
Pop-up blockers are software programs that stop unsolicited "pop-up" browser windows from launching automatically. These windows often feature advertisements that can be an annoyance to users trying to browse the Internet, however some features of the Webcast may make use of pop-up windows to deliver key functionality. Depending on the software progam you have installed you may be able to add the Web site URL to a list of permissible Web sites where pop-up windows are allowed.
It is common to have one or more pop-up blockers that you may be unaware of. Most pop-up blockers reside either in the system tray (lower right hand corner of your screen by the clock) or as a toolbar in Internet Explorer (at the top of your browser, go to "View" and then "Toolbars"). These can be disabled in their options or preferences menus. (Common toolbars such as Google and Yahoo Companion have built in pop up blockers).
Also, if you are unaware of any other pop-up blockers that are running on your computer, you may want to see if you have personal firewall software running, such as Norton’s Internet Security or ZoneAlarm. If you have either of these, they will also block pop-up windows.
Where can I download the latest streaming media players?
– Windows Media Player – http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx
– Adobe Flash (for viewing Application Demonstrations and Video Roll-ins) – http://get.adobe.com/flashplayer/
Where can I download the latest Internet browsers?
– Microsoft Internet Explorer 8 – http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
– Previous versions of IE – http://www.microsoft.com/windows/ie/ie6/downloads/default.mspx
– Firefox – http://www.mozilla.com/firefox/
I occasionally hear a clicking noise during the presentation. How do I turn it off?
- Windows 7 – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows Vista – Click on the Windows Start icon, then choose "Control Panel" > "Sound," > "Sounds" tab. Scroll down the "Program" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
- Windows XP – You can disable this noise by going to the Start menu, then "Control Panel". Open "Sounds and Audio Devices," and click the "Sounds" tab. Scroll down the "Program Events" menu until you reach "Start Navigation." Set the sound to [None] and click "OK." The clicking will be disabled.
In addition to having a properly installed Adobe Flash Player your pc must permit rtmp (over port 1935) and / or rtmpt (over port 80) live streaming protocols. Please contact your local IT Administrator if you are unsure of your settings. IT Admins can click here to review additional information on configuring proxy servers to permit live Flash streaming.
Questions? |
Please contact the ELECTRIC POWER Conference Manager, Kim Arellano at (713) 343-1879 or email: kima@tradefairgroup.com
