Did you know that Val-Matic’s Plug Valves have 100% port? An excellent choice when you have more than just water flowing through your system such as when slurries, grit or solids are present. Its eccentric action allows the plug to rotate and lift out of it seated position minimizing rubbing or scraping. Features such as a heavy-duty fully rubber encapsulated plug, welded nickel seat, grit-seals and V-Type packing provide reliable operation. Val-Matic Plug Valves are built using advanced manufacturing technologies and are certified to rigorous industry standards to assure reliable performance. Fusion Bonded Epoxy, Rubber Lining or Glass Lining coatings are available when necessary. For more information on Val-Matic Plug Valves visit www.valmatic.com.
About Val-Matic
Val-Matic Valve and Manufacturing Corporation’s headquarters is located in Elmhurst IL with additional manufacturing facilities in Addison, IL. Val-Matic is a leading manufacturer of Air Valves, Check Valves, and Quarter Turn Shut-Off Valves for water/wastewater, power, industrial, fire protection and HVAC applications.
