Environmentally Safe Chesterton 650 Advanced Machinery Lubricant Handles High Load and Extreme Pressure
Biodegradable 650 AML Extends Equipment Life by Significantly Reducing Wear at High Loads
Groveland, Massachusetts
Chesterton is pleased to announce a one-for-all 650 Advanced Machinery Lubricant (AML) for chain, pneumatics and other machinery assemblies in industrial, and food and beverage markets. It is formulated with a unique food grade plant-derived ester blend, making it a high performing, readily biodegradable, environmentally friendly, and worker-safe lubricating oil. 650 AML provides outstanding protection against wear in valves, pistons and other pneumatic components. It cleans and removes gums and varnish while lubricating chains, ropes and other machinery assemblies.
650 AML is designed for the end users that are looking for a high-performing, environmentally friendly and worker safe alternative to petroleum-based oils. 650 AML will meet safety and environmental compliance and will perform better than many petroleum-based products.
650 AML has several benefits when used for lubrication of pneumatics, chains, ropes or machinery assemblies
- Environmentally safe plant derived ester technology; readily biodegradable
- Low mist hazard; low odor
- Self-cleaning; removes residue and sticky build up
- Low coefficient friction of 0.05 (ASTM D3233), significantly reduces power consumption
- Reduces wear, scar diameter of 0.395 (ASTM 3233), prolongs equipment life
- Silicone free; Safe on all metals, most polymers and plastics
- NSF H1 certified, allowed to use in food, beverage and pharmaceutical industry
650 AML is intended for all industries. It will prove significantly beneficial in the industries where the pneumatic applications require high moisture absorption and dry chain applications require high weld carrying and excellent cleaning ability.
Intended areas of use are, but not limited to:
- Robotic, automated and process controlled pneumatic systems containing pneumatic cylinders, solenoids, actuators, valves, presses, air tools, etc.
- Assembly/conveyor chains: Such as automotive assemblies, general manufacturing (white goods, tire and rubber, pulp and paper) and lubricant applied by automatic mist or spray lubrication systems
- Wire rope, cables and hoists for cranes, lifts and conveyors
- Air mist lubrication of bearings for higher speed; hot services to 392◦F (200◦C) depending on bearing size and rpm
About A.W. Chesterton Company
Operating in over 100 countries around the world, Chesterton is recognized as a leading provider of knowledge backed solutions and expert service for Rotary, Stationary, and Fluid Power equipment supported by a comprehensive line of industrial fluid sealing solutions, high performance protective coatings, and specialty industrial lubrication/MRO products.
