Economical Positive Displacement Pump
SPX Process Equipment last December introduced the ProCam SMART, a Bran + Luebbe positive displacement pump capable of a wide range of metering duties at a low initial investment. Available in four models offering flow rates ranging from 1.3 gph to 132 gph and suitable for pressures up to 290 psi, the ProCam SMART is geared to several applications, including chemical degassing, oxygen scavenging, corrosion inhibition, caustification, and decarbonizing. The hermetically closed pump contains a mechanically operated PTFE double-diaphragm arrangement, the performance status of which can be monitored. All wetted components are made from stainless steel, and the cast iron gearbox contains a splash-lubricated integrated worm wheel/shaft reduction gear. (www.spx.com)
