February 15, 2007
Arc flash protection should be job No. 1
Pages: 1234
Assumptions and complacency are two of safety's worst enemies. If the following story hits uncomfortably close to home for you, it will have served its purpose.
In January 1993, two employees were killed and three were seriously injured by an electrical arc flash at a Texas power station.
The dead employee—an operator in a full flash suit—had racked-in a circuit breaker and sent the close command, but the breaker failed to close. With the breaker indicator showing that it was still open, the operator began racking-out the breaker to troubleshoot the problem with his supervisor looking on. Neither knew that the breaker had received the close command. The breaker had unlatched and begun to close, but the mechanical problem prevented it from completing the operation.
As a consequence, the operator attempted to rack out the breaker even as it was receiving a close command. When he was finally able to move the breaker, the mechanical bind was relieved and the breaker closed while it was partially racked-out. The result was an electrical arc flash and explosion that critically burned the operator and the supervisor and slammed them into wall. Both were killed. The arc flash then traveled around a corner and burned three other workers. All of this carnage occurred within milliseconds.
The operator, in addition to wearing a full-body flash suit while racking the breaker, did everything that National Fire Protection Association (NFPA) and Occupational Safety and Health Administration (OSHA) regulations required. Although the suit provided some protection, it did not save the operator's life. The moral of this story: If the arc flash burn doesn't get you, the high-energy blast effects will. Entergy learned the lesson quickly; immediately after this accident, the company began retrofitting all of its rackable breakers rated at 2,300 volts or higher with remote racking systems (see box).
Pages: 1234
