To optimize performance, begin at the pulverizers
Pages: 12345
Optimizing combustion in pulverized coal (PC)-fired boilers today is more important today than ever. It is well known that the average American PC plant is over 30 years old and that over its lifetime NOx and SO2 emissions limits have been steadily ratcheted down (see box). Today, operators no longer wonder whether permissible levels will continue to fall but, rather, when and by how much.
The newest fork in coal-fired generation's path forward is determining how to capture plant emissions of carbon dioxide (CO2) when—not if—the gas is regulated as a pollutant. Some advocate widespread installations of unproven integrated gasification combined cycle (IGCC) technology ASAP, to prepare it as a long-term solution. Others say building fleets of super-efficient supercritical and ultrasupercritical-pressure and -temperature plants would be a timelier, more prudent, and more cost-effective alternative. But while regulators, Congress, and the courts wrestle with the question of what to do about greenhouse gases, one thing remains clear: CO2 emissions could be lowered considerably by raising the efficiency of the existing U.S. fleet of 1,100+ coal plants.
Today's average U.S. PC-fired plant operates at a heat rate of about 10,500 Btu/kWh. Yet a subcritical (2,400 psi/1,000F/1,000F) unit is capable of operating at least 10% more efficiently, at a heat rate of 9,500 Btu/kWh (Figure 1). There are many proven ways to improve a boiler's performance by continuously optimizing its controllable variables (see box). This article explores opportunities for raising a unit's efficiency by improving the performance of its pulverizers.
1. Room for improvement. The heat rate of most older coal-fired steam plants could be lowered by improving their combustion air and fuel systems. Source: Storm Technologies
Storm Technology's experience has demonstrated that, of the 20 key O&M controllable variables with the greatest impact on unit heat rate (see box), most involve the furnace's "burner belt." Essentially (and most often), in a plant operating at its lowest possible heat rate, the combustion airflows, pulverizers, fuel line balancing, burners, and air heaters will all be optimized.
Despite all the changes in regulations, equipment, fuels, and combustion controls over the past few decades, one thing has not changed in evaluating pulverizer performance: You need to get the inputs right! Table 1 breaks down the potential heat rate improvements achievable from giving your pulverizer and related systems a good tune-up.
Table 1. Pulverizer improvements are significant and easy to accomplish. Source: Storm Technologies
Pages: 12345
