ELECTRIC POWER 2009 Exhibitor Preview
Pages: 12345678
Integrated System Descriptions
HPC Technical Services has taken system descriptions to the next level and is excited to introduce the Power-Doc, which includes the following in one document:
•    Interactive system description,
•    Interactive P&ID,
•    Interactive alarm response manual
•    Interactive instrument loop diagram
First, HPC writes an equipment-specific system description, adds images of your equipment, and includes your P&ID completely redrawn in color. This colorized version has the same detail as the original drawings and is a definite plus when tracing system piping and/or troubleshooting system problems. Next, HPC adds links to the P&ID, images, and system description to allow the user to jump back and forth within the Power-Doc. The resulting Power-Doc is a great tool for operating/troubleshooting each system.
If an alarm occurs in the control room, operations personnel open the Power-Doc, select the appropriate Alarm Title, and immediately view a list of probable causes and probable operator responses. They can also select the P&ID on the screen and go immediately to a highlighted P&ID of the system in question or select the instrument on the P&ID and see an Instrument Loop Diagram that shows the instrument, the wiring, and calibration data.
I
Imbiber Beads
Award-winning Drain Protection Systems (DPS) from Imbibitive Technologies America are designed to allow rainwater to drain but automatically seal the leak path in the event of an oil release. Imbiber Beads®, used by the DPS, selectively remove organic liquids including PCBs from water. Imbiber Beads are discussed in the Design Guide for Oil Spill Prevention and Control at Substations, USDA-REA (RUS) Bulletin 1724E-302, the USEPA final rules for SPCC compliance, 40 CFR Part 112 (2002) as well as in the IEEE Guide for Containment and Control – IEEE Std. 980.
Imbiber Beads are the only true aBsorbent (ASTM F716) “engineered” for organic chemicals. They are not an aDsorbent and they are not a thickener/solidifier. Imbiber Beads will not dissolve in excess liquid. Water can not be absorbed by Imbiber Beads as they are hydrophobic. Imbiber Beads Imbicator® (changes color) Spill Maintenance Products (booms, blankets, pillows and packets) are also available for capturing and containing compatible organic chemical (fuels, solvents, mineral oil) releases.
Enhanced 3D Electric Field Solver
INTEGRATED Engineering Software, a leading developer of hybrid simulation tools for electromagnetic, thermal, and structural design analysis, has launched an enhanced version of its COULOMB 3D electric field solver software. Fast and accurate, COULOMB's calculations include electric field strength, transmission line parameters, and capacitance. It is suitable for applications such as high-voltage shielding, transformers, insulators and bushings, transmission lines and lightning arresters.
COULOMB has always offered a successful integration of an effective calculating method with accuracy and an engineer-oriented approach. Powerful parametric solvers allow designers to automatically vary and experiment with geometry, materials and sources, reducing the tedious, repetitive task of fine-tuning multiple design parameters. Version 7.0 of the software includes features such as self-adaptive 3D Finite Element Method and a better use of memory. The self-adaptive 3D FEM feature has been significantly enhanced and is now quicker to converge with less iterations. The only practical limitation for this feature is the amount of RAM available on the workstation. The program can now solve larger FEM problems up to 10 times faster than previously.
Water Treatment
Itasca Systems and its parent corporation, H2O Innovation, have a solution for all of your industrial water treatment needs. Our talented team designs, builds, and services every Itasca water treatment system with a sense of commitment and dedication that is unparalleled in the industry. We are a custom manufacturer that can build a system to your exact specifications with versatility and innovation. Our engineers see our projects through to the very end, so you can always count on us to listen to you and help you through every phase, before and after the job is done. Whether you need a high-quality membrane system for your high-pressure boiler or a waste water system for your plant effluent, we have knowledge to share.
J
Fire Protection
Janus Fire Systems is an integrated supplier of fire protection products and services for the power generation industry. Janus Fire Systems designs special hazard systems using a variety of products. Carbon dioxide fire protection systems have been effectively used to protect base load fossil and nuclear plants, as well as combustion gas turbines for years. In an unprecedented move, the NFPA 12 committee mandated safety upgrades for new and existing carbon dioxide systems to be completed by December 31, 2008. The National Fire Protection Association’s (NFPA) Standard 12 has been the definitive guide for design, installation, and maintaineance of carbon dioxide systems since its adoption in 1929. Required system modifications include upgraded signage, lock-out valves, odorizers, and pneumatic discharge delay timers—all to reduce the chance of a carbon dioxide discharge in an occupied space.
The Janus Fire Systems engineering team reviewed existing low-pressure carbon dioxide systems with the focus of becoming compliant with the new standard. In the process, they designed a proprietary Universal Pneumatic Time Delay System that meets the requirements of NFPA 12, section 4.5.6.1. This preassembled unit can retrofit all brands of low-pressure carbon dioxide systems.
Crawler Cranes
JPW Riggers, Inc./JPW Structural Contracting, Inc., based in Syracuse, New York, have been servicing the industry since 1953. JPW Riggers offers one of the largest fleets of Manitowoc 16000 crawler cranes in the country, as well as Manitowoc 2250’s, 999’s and 14000 series cranes. JPW also offers a diverse selection of hydraulic, rough terrain, and all-terrain cranes.
JPW Riggers offers nationwide service. JPW Structural Contracting is an AISC certified steel fabrication and erection facility with a 120,000’ state of the art fabrication complex located in Syracuse, NY. JPW Structural offers the latest in CAD technology and steel fabrication equipment. JPW Erectors was the first steel erector in New York State to be awarded an ASIC certification in complex steel erection. JPW is number one in safety compliance.
K
Bearing Repair and Service
There are many reasons why bearings fail in rotating equipment. Failures occur from contaminants in the oil such as quartz and sand, metal chips, fly ash, and weld spatter. Bond failures occur from improper cleaning, dirt, gases, pour bonding techniques, oxides, reused or bad babbitt, etc. Cavitation erosion and corrosion are other means of failures. Fatigue failure is the cracking and fracturing of metals due to excessive cycling. There are other failure reasons such as overheating, electrical pitting, high-chromium damage, seizure from improper clearances and misalignment. There are many reasons that are recognizable and there are many that are very difficult to distinguish.
Kingsbury Repair & Service Division
provides you with experienced personnel to help recognize problems and work out solutions. Kingsbury provides quality control unmatched in the repair industry. If we need to resolve a problem such as redesigning a bearing, eliminating or reducing shaft currents, increasing loading capability, installing temperature probes, or providing a field service engineer, we can handle it.
Key Interlock
Since 1932, Kirk Key Interlock Company has continually demonstrated its commitment to the key interlock industry. Now, we are introducing a new logo that symbolizes the company’s past, present, and future. Along with our dynamic new logo, Kirk Key Interlock Company will re-launch kirkkey.com to feature multilingual content and convenient, yet secure, access to your order information (i.e. shipping date, tracking number, etc.) as an extension of the professional and courteous customer service you have come to expect.
High-Pressure Screw Compressor
High-pressure screw fuel gas compressors (API-619) are now available up to the high-pressure range of 100 barG (= 1500 psig), allowing the high-pressure screw compressor to cover most of the areas traditionally handled by reciprocating compressors. This means that owners of gas turbine power plants can fully enjoy the higher reliability and long-term continuous operation with lower maintenance offered by the high-pressure screw gas compressors, without suffering from difficulties due to the frequent maintenance required by reciprocating compressors.
In addition to more than 250 sets of experience for all types of gas turbines, Kobelco has already delivered several sets of screw fuel gas compressors for GE LMS100 in the U.S. and Canada, which requires higher pressure fuel gas due to its high efficiency. The positive displacement screw gas compressor continues to offer the original great design benefits, such as higher reliability, lower maintenance, environmental friendliness, flexibility for changeable operating conditions, plus tremendous power saving by the slide valve mechanism. Kobelco higher pressure screw gas compressors can now bring even more benefits to gas turbine power plant.
Ring-Section Pump
Power generation stations play an important role in meeting today’s energy and environmental needs. KSB’s high-pressure ring-section pump is designed with state-of-the-art technology that will improve your overall plant performance while meeting these needs. The HGM is an environmentally friendly pump that requires no oil, no cooling water, and is essentially maintenance free. Together, these features give you a product that not only leads the field in quality, efficiency, and reliability but also keeps your energy and life cycle costs down.
L
Rotating Equipment Repair
L&S Electric works hard at keeping you working. With the current economic environment that we’re in, that core belief has never been more important. We offer comprehensive rotating apparatus repair capabilities regardless of brand. Our network of service centers feature complete diagnostic and testing capabilities for almost any type of rotating equipment. The L&S Electric name has become synonymous with recognized leaders in modernizing hydroelectric controls, with the best value in digital governors, automation, excitation, and digital relay protection systems.
The power service team provides complete service for all power system components, regardless of voltage, including troubleshooting, commissioning, turnkey installation, repair, calibration, testing, and system design. Our reliability service team specializes in custom predictive maintenance programs designed to detect equipment problems before they cause costly downtime. Using state-of-the-art technology and training, our reliability team can eliminate any future headaches that may cost you a fortune. With convenient locations throughout the upper Midwest and Canada, L&S Electric offers capabilities unlike any other company. From small motors to large hydroelectric generators, we offer unparalleled service. With total on-site and in-shop services available 24/7, L&S Electric is your complete source for all your service needs.
Lectrodryer Fast Degas CO2 Evaporator
The Lectrodryer Fast Degas CO2 Evaporator system allows for quick degassing of the generator while preventing lines from clogging due to ice forming as a result of CO2 expansion. The Fast Degas CO2 Evaporator has the ability to deliver 305 SCMH of CO2 to the help reduce the time and cost involved during outages by allowing the generator to be degassed and brought back online much more rapidly. This system also provides an important safety benefit by rapidly blanketing the generator with inert gas in times of upset conditions or emergency situations.
Portable, Multi-Process Power Source
Lincoln Electric’s new Power Wave® C300 is a portable, multi-process power source with high-end functionality, ideal for applications and materials where arc performance is critical, including aluminum, stainless steel, and nickel. The Power Wave C300 provides one machine for nearly every weld application, including production welding, construction, aerospace, automotive repair, general fabrication or a training environment.
The machine features Lincoln’s new PowerConnect™ Technology to automatically switch from 200 to 600 volts, 50 or 60 hertz, and single- or three-phase welding with no manual reconnect and a constant welding output. It also features:
•    Patent pending technology that allows for automatic input voltage reconnection
•    Advanced user interface customizable for multiple operators, processes, and settings
•    Industry’s highest efficiency rating at 88 percent at 250A with a 0.97 power factor
•    Standard Production Monitoring™ 2 software enables weld data to be monitored
•    Durable and rugged case designed for harsh environments
The machine is IP23 rated and weighs just 91 lbs, making it easy to transport for off-site applications, and its Waveform Control Technology® provides superior arc performance and allows users to download applications free of charge from www.powerwavesoftware.com.
M
Pages: 12345678
