April 1, 2009
ELECTRIC POWER 2009 Exhibitor Preview
Pages: 12345678
This year's ELECTRIC POWER Exhibition will feature the latest technologies and services from approximately 500 companies. Get a preview of some of the exhibitor offerings here. For the entire offerings, you'll have to visit the show floor in Chicago this May. (You'll find all the event information here.)
This exhibitor preview is arranged alphabetically by company name (in bold). If you know the name of the company you're looking for, or to find a particular type of product, search this page by keying Ctrl-F (PC) or Command-F (Mac) and then typing the keyword(s) in the box at the bottom or top of your browser window.
A
Wear Protection Systems
Abresist Corporation,
a Kalenborn Company, introduces two new KERAFLEX wear protection systems, consisting of ALRESIST® high alumina ceramics or KALMETALL®W hard overlay welding plates vulcanized to a steel base. These systems are well suited where high abrasion and impact occur in combination. Maximum operating temperature is 176º F/80º C.
KERAFLEX reduces noise and is especially well suited for use in transfer chutes in belt conveyor systems and impact zones in bunkers and silos. These wear protection systems are produced in standard panels, up to 20” square, with welded studs or countersunk bolting attachments. KERAFLEX-KRM consists of ALRESIST high alumina ceramics with a tile thickness of ½” or 1”. The thickness of the rubber is determined by the severity of the impact. KERAFLEX-WRM consists of KALMETALL-W hard overlay welded plates, rubber and steel. KERAFLEX-KR, with 1/8”- to 1/2”-thick ALRESIST tile and a rubber backing only, provides for a flexible lining that is glued in place.
The Ultimate 3D Flow Measurement System
The 3D Probe Data Acquisition System (3DDAS™) sets a new standard for volumetric flow measurement systems for use in stack/RATA testing, fan outlet ducts, mill inlet ducts, and general ductwork. It is fully compliant with EPA Methods 2, 2F, 2G, and 2H and weighs just 22 pounds.
The 3DDAS boasts the ability to secure the most accurate measurements possible. Gone are the days of “sight weighted averages.” The 3DDAS takes 1,000 readings per second and calculates averages instantly. This is achieved with 3DPROBE™, state-of-the-art software that simplifies and expedites the testing process. It automatically generates test configuration information, records data, completes error checks, and outputs reports detailing velocities, pressures, temperatures, and flow rates.
Designed and built by Michigan-based Airflow Sciences Corporation, the 3DDAS also features a rugged industrial NEMA 4/12-rated computer, 16-channel and 16-bit data acquisition board, touch screen navigation, and wireless remote transmitter interface.
Utilizing Hot-Dip Galvanizing In Alternative Energy Projects
The American Galvanizers Association is pleased to announce the release of Sustainable Solutions for Corrosion Protection in Alternative Energy, an informative publication (available at www.galvanizeit.org/publications) detailing research regarding the strength and sustainability of hot-dip galvanized steel in the alternative energy market.
Sustainable Solutions explores how utilizing hot-dip galvanized steel in biofuel, wind, hydroelectric, and solar structures not only protects them from the effects of corrosion but also is highly sustainable and earth-friendly. Highlighting the inevitability of corrosion, this publication stresses the importance of making intelligent environmental and economic decisions, supported by real-life case studies from each sector of the alternative energy market. It also explains how the natural, recyclable zinc coating created in the galvanizing process will provide superior corrosion protection without requiring the costly carbon footprint of maintenance.
Increased Emissions Reductions
APTECH CST has developed a new very affordable technology (patents granted and pending) that will achieve better than 70% reductions in SO2 and NOx. If needed, reductions of more than 90% can be achieved with companion technologies such as low-NOx burners for NOx and small polishing scrubber for SO2. Reductions approaching 100% can be achieved for SO3 and chlorides. A significant reduction in mercury is expected and should exceed 90% using a bag house. Slag formation in the upper furnace and convective pass can be eliminated or dramatically reduced.
The capital and operating costs for the combined technologies are less than 8% of the cost of a scrubber and SCR, making them especially attractive because no large external structures required. Parasitic power is less than 0.5%.
Multi-Barrier Seal for Troughing Belts
Arch Environmental Equipment Inc.
announced in January the release of the Talon® Seal, a skirt seal that utilizes the “more is better” theory. Manufactured with wear-resistant EPDM rubber, the Talon Seal minimizes belt friction using a multi-barrier seal design to guard against fugitive dust and spillage. The unique design includes a flexible heel and toe that auto-adjusts to belt sag and troughing angles maintaining a consistent, spill-proof seal. Resistant to ozone, weather and UV factors, the highly durable Talon Seal withstands temperatures up to 250° and is available in continuous lengths up to 600 feet.
Consistent with Arch’s goal of providing products that are simple to install, use, and maintain, this seal is easily installed using existing clamps and automatically conforms to the dynamics of any toughing conveyor belt without maintenance. Arch Environmental Equipment is a manufacturer and distributor of a wide range of mechanical and electrical products designed to improve the efficiency and safety of conveyor belt systems.
Bulk Conveyer Components
ASGCO Manufacturing Inc.
is a leading manufacturer and service provider of proprietary bulk conveyor components that enhance bulk material-handling performance. We use proven products and technologies to provide our customers with solutions to their conveyor material-handling problems.
Essential attributes of present and future growth are the following:
•    Develop productive cost-effective and technologically advanced, safe and reliable products specifically for the bulk material-handling industry.
•    Establish a national and international network of local distributors that are selected based on their expertise in the conveyor material-handling industry and their commitment to 24/7/365 customer service.
•    Provide assistance to customers that require specific application advice, customized products, or fabrication from installation through ongoing services with tailored maintenance.
•    Actively continue to provide our distributors and customers with conveyor-training programs.
•    Maintain a safe working environment for our employees.
B
Precast Concrete Trench Systems
An alternative to direct burial, Con-duct offers you a modular or one-piece concrete encasement that enables you to protect your cables or pipes from light pedestrian traffic or heavy truck traffic. Barkman Concrete’s design allows for future expansion and the flexibility to create angled corners, tees, and 90 degree corners, if needed.
Various options include unistrut inserts, weld plates, cable support blocks, grounding clips and divider panels to meet the needs of your application. Our support staff will provide you with technical data and detailed drawings as well as consultation services while the product is being installed. Standard, easy-to-remove, concrete covers are available along with lightweight GFRC lids, both giving superior protection and easy access to your electrical or mechanical system without having to resort to excavation.
Online Ash Analyzer
Berthold Technologies,
well-known as a manufacturer of non-contact, non-intrusive measurement systems, has launched the newest generation of its ash analyzer - the LB 421 AshAlyzer, which measures the process online and in real time. Due to the real-time availability of ash content and calorific value, loading, unloading, production and preparation processes can be optimized. The supply of consistent coal quality is therefore guaranteed, which leads to significantly increased efficiency.
The modular concept of the AshAlyzer allows an easy application to the individual needs of customers’ measurement requirements. In addition to the analysis of ash content and flow rate using the tried and tested gamma transmission method, the energy and moisture content of coal can be determined by integrating an additional microwave measurement system. Features such as high detection sensitivity and stability ensure high reliability and accurate measurement results. The AshAlyzer has the industry standard IP65 with an easy-to-use touch screen operator interface, making it ideal for use in the coal industry.
Electric Power Technology Courses
Bismarck State College’s National Energy Center of Excellence offers online and classroom training for the energy industry. Associate in Applied Science (AAS) degrees can be earned, or courses can simply be taken for professional development and training. Classes are available in Electric Power Technology (distribution), Electrical Transmission Systems Technology (system operations), Power Plant Technology, Process Technology, or Nuclear Power. In addition, a Bachelor of Applied Science degree in Energy Management is available entirely online.
The classes are offered in a convenient block-style format, giving students the opportunity to complete a class in three to six weeks. The National Energy Center of Excellence is also known for its non-credit offerings such as apprenticeship programs, customized training, and NERC CEH courses.
Advanced Silicon Carbide Products
Blasch
Precision Ceramics InVinCer by Blasch™ lines of advanced silicon carbide products deliver superior wear resistance for power generation applications. Blasch’s new reaction bonded silicon carbide (SiSiC) offers excellent wear, chemical, oxidation, thermal shock resistance, and the highest thermal conductivity to its maximum use temperature of 1,380°C. Available products include burner nozzles, pump components, mechanical seals, micronizers, and cyclones. Custom shapes are also available upon request. Highly abrasive wear and corrosion applications include FGD nozzles, burner liner blocks, pipe bend liners and other highly abrasive power generation applications.
Blasch’s recrystallized, RSiC, silicon carbide offers very high strength, excellent thermal shock, oxidation, and abrasion resistance to its maximum use temperature of 1,610° C. Available products include burner nozzles and specialized structural members, as well as custom shaped parts.
Boro-Block Borosilicate Stack and Duct Liner
Blome International
is pleased to announce the addition of Boro-Block Borosilicate Stack and Duct Liner to its product line for FGD service. Boro-Block has many years of International success and has been specified and used by several U.S. utility companies in the past year. Not only does the Blome system outperform competitive materials, but it also is covered by a full 10-year warranty backed by a domestic insurance carrier. Boro-Block is suitable for use on steel, concrete, or brick substrates and could minimize loss in the event of a fire.
Blome International is a U.S. company with over 35 years of proven performance in the power industry. Our coatings are formulated and manufactured in house to maintain the highest level of quality on the job.
Wood-Handling Expertise
For the past 20 years the BRUKS Rockwood team has been developing and supplying materials handling solutions for customers who process and burn wood residue. The demand was initially centered on pulp and paper producers who had the desire to efficiently turn process waste into fuel. As the energy market has evolved this desire has expanded from the pulp mills into a variety of different arenas.
Today, demand for such solutions ranges from gas-fired boiler operators to producers of wood-derived fuels such as pellets. Most of these systems can be broken into three distinct segments: materials handling, production, and delivery. The BRUKS group focuses on the materials handling segment or the front end. In this area the materials are received, cleaned, sized, stored, and then delivered to the production island. A recent example of such a project is Green Circle Bio Energy located in Cottondale, Florida.
C
Pages: 12345678
